It was bogging on the line, had to just tickle it away and then give it some.
Need to play with the tyre pressures and may have to swap out for a 433 or 456 gear ( using 411 at moment ). Summit ring and pinions are $143 each and come packaged in richmond wrappers.
You re right ... Only had 25 psi in the front and 8 in the back as it was first run with it I didn't want any airborne drama
Usually run 45 psi in the front and 10 - 15 in the back
Only using a 9 inch tyre on back so may possibly step up to a 10.5 ?
This was very much a shakedown run just to make sure it went straight and didn't suffer with the added high up nose weight
Now I know its ok I can start getting it set up better
Thanks nick
