Procharged 440
- Cannonball
I had a gentle launch at 2000rpm and ran 9.8 @ 138mph, it was a bit down at 135 when it went.[/quote]Turnip wrote:[quote="Cannonball
and we are all dying to know how fast did it go begore bang, ???
so how many runs before it died jon ???
Ivor it would have been more of a mess if I had put gas through it
Alan the crank was from Hughes, I can't remember of hand exactly which one, the rods are Callies CompStar and ceramic coated pistons.
The part of the block that a lot of pepole told me would break seems to be the only part not damaged
It looks really odd. It was put together by Dave Milam, he was on the phone first thing Monday morning after he had heard about it. He wants to try and work it out as much as we do. Just need to pull it out and get it over to him.NaughtyAlan wrote:Obviously not a good day Turnip, who built the engine? , this sort of carnage should not happen had the engine been built to a decent standard
, something went badly amiss when this engine went together , not trying to be the grim reaper but truth sometimes hurts , sorry.
Aka Brutus.
Take a piece of coat hanger or similar, Bananarama! through the oil hole in the Main bearing, if it comes out the other side its a cross drilled crank.
These cranks can be ok but require a lot of oil pressure to overcome the neg effects of centifugal forces caused which pull oil away from the rod bearings. High oil pressure has its own problems.
It is imperitive that your man checked all the oil holes in the crank for any blockages and or holes not fully drilled far enough before installation.
Just something to consider.
Les
Les
