RobTwin wrote:Hi Rich
How did you get on at Bob Harman's?
Get anywhere with your vibration probs - was it anything to do with the exhaust system being fixed too firmly to the car?
Hi Rob.
Yep it was a combination of the headers and exhaust bolted up to tight along with all the (Steel) brackets fixed to the car. The ujs on the prop were shot. But Bob and Cliff also found that the distance on the end float was way off, after some careful measuring and testing shims were put in place and ha presto the car has never drove so good. It took a while but we got there in the end. I must have spent hrs under their looking and checking.
But these guys ex Rolls Royce mechanics went straight to the fault.
Apparently because we are always moving, fitting new or used gearboxes,props,diffs the actual distance of torq travel is often missed out, so with a one piece prop and weight just the smallest distance could make all the difference. Hope this helps anybody else who has the same probs.
Richard.
072
