venturi.
The temperature drop of 20?30?C results in atmospheric moisture turning into ice which gradually blocks the venturi. This upsets the fuel/air ratio and strangles the engine.
Then when you stop by the side of the road, the heat in the engine then seeps through the intake manifold, to the carb and de-ices it and hey-presto no more problems.
I had similar problems on one of my old Land Rovers and I ran a copper strip from the exhaust manifold stud to the carb stud, directly under the carb and that fixed it.
I'm sure there is a connection between the fuel air density too, so it may be worth checking your mixtures...the Land Rovers' was right up the creek because the carb was knackered.
HTH!
