power required?
Dave, Holley make a 390cfm 4bbl. They pop up regularly on the NSRA forum as they are popular on Rover V8 engines. Also popular on tuned slant sixesDave wrote:An otherwise stock 273 engine will only need a 500-550cfm 2bbl. That equates (they are measured differently) to a 360-400 4bbl and I don't think they make them that small.
Any bigger and you will loose throttle response and driveability.
- Stu
'Tis true. We have a spare with a rebuild kit that owes us some money, don't we, Bro? 390 took us up a peg, but we did quite a bit of other stuff too.Gareth wrote:Dave, Holley make a 390cfm 4bbl. They pop up regularly on the NSRA forum as they are popular on Rover V8 engines. Also popular on tuned slant sixesDave wrote:An otherwise stock 273 engine will only need a 500-550cfm 2bbl. That equates (they are measured differently) to a 360-400 4bbl and I don't think they make them that small.
So what is the current spec?
- Stu
Oh, hang on... I just remembered how to read...Lance wrote:As for removing seats and saving weight, grand ideas but not the direction i want to take.
Now a 360 sounds more like the sort of thing i was thinking of, perhaps i should have given more detail, the dart has a 270 V8, 3spd auto (no kick-down at the moment) and a 71/2" axle, would it be feasible to make the required changes(engine, trans + axle) for say a grand - 12 hundred quid??or am i dreaming, i want to share the total budget between paint interior and power increase.
- Trigger_Andy
Aussie CH barges had the full luxury trim were big and heavy
had a 360 and the borgwarner axel which is 7 or 7 1/4 inch
this was through an auto so they are kinder to the diff than clutch and manual but
unless you drag race or use engine brakeing in the extreme the axel should hold up fine
Its the sudden application of torque or a sudden loss of, or regaining of traction under hard aceleration (especially one wheel) that kills a box or an axle not necessarily the ammount or torque you have you have on tap or indeed the peak power output.
Granted gunning anything away from the lights every time will eventually wear out a diff but you wouldn't need to drive it like it was made of glass either.
at least with a 7 1/4 parts should not be an issue eveyone else will have pulled it out and replaced it with a big one so there should be a supply already here to keep you going for a good long while.
nobody wants the aussie ones so I've picked up two for £75 a pop
would guess proper US ones are just as popular (especially non LSD)
wow!! a lot of info to consider
, OK, what if i take the option of reworking my 273? as far as i Know when fightin fit in standard tune it should be about 190HP??? (correct me if I'm wrong please) or is it not worth the effort and expense?.
1,what could i expect to get and stay reliable?
2, what improvements would be most effective?
3, rough cost?
3, rough cost?
