just an update, got the suspension set up today as per Dave's settings. Well nearly, the guy couldn't get any more than negative 1/2 degree on the camber as there is still too much wear in the bushings that weren't replaced. - but it is a lot better than the positive 2 1/2 degrees that she was set for this morning! Driving well enough to make it to the Nats, but the steering is less good than it was. There is quite a bit of wear on the box and the idler bushes, and I know that, but it seems that every MOT tester and mechanic that sticks his pry bar in there is making it worse....
Oh well, mustn't grumble...
Thanks everyone for your help - I'll get that manual back to you on the way to the Nats. Nige if that is ok?
Cheers,
Nick
