Mad plumber fits hot 440 in Ford Transit
Del , was deep in thought , wondering if D Billydooooooos would notice if i swapped the Wedge over for the Hemi. :clown:
As some of you know , the 440 went up Norf to have the pistons/rings checked , while it was appart , replacment rings went in & gapped for nitrous , the six pac rods were also changed out for better ones.
Had the valve covers changed , as the mopar ones were twisted , & leaked like a sieve. The dual plane intake was changed for a single plane , again for the nitrous. :roll:
Heads were lightly ported (cleaned up) , the block was decked (just a clean up really)
Hopefully tide me over till the stroker is built. :twisted:
Adam68 wrote:Hopefully tide me over till the stroker is built. :twisted:
Said the Nitrous junkie to the the Dealer :D
Tide me over, that made me laugh :)
big b1 would end all them nitrous thoughts, ;)
Hear what yer sayin Duncan , i'm just bein pig headed regarding the port window set up & comp ratio.
Can't run it on race gas on the street , the other half won't allow another re mortgage. :roll:
Adam68 wrote:Can't run it on race gas on the street , the other half won't allow another re mortgage. :roll:
I can hear yer brain whirlin Adam..... Now if I worked from............. Extra cash for the weekend, postponed me hols, [-o<
Maybe I need................... :help:
Adam68 wrote:Hear what yer sayin Duncan , i'm just bein pig headed regarding the port window set up & comp ratio.
only strokin yer ad you know that, you need a bad racecar between you noneck and knightcharger call it the alchohol raceteam :D
AllKiller
Post by AllKiller »
Never knew you had Ali heads on the Pit Adam :shock:
ALL KILLER NO FILLER
AllKiller wrote:Never knew you had Ali heads on the Pit Adam :shock:
oh yes allkiller and it was 493 cubes , now gone to 535 ;)
BUDGIE
Post by BUDGIE »
:shock:
And ya couldn't get an 11.00.......... :shock:
:shock:
Wondered about that Mal , since found out the babys bottle was wedged under the pedel. :roll:
:D
:D
:binky: :roll: ;)
AllKiller
Post by AllKiller »
:shock:
Pah :roll:
Come on did i miss something ??
last Nats what did you have in the Pit..... 440 or 493 with or without Ali heads.
just interested :?
Grass im up
Steve Im not normally a grass but-------
440 +30 eddy perfs demon 750.
And a light right foot. :D
I keep telling Ads its like sex "DON'T LET OFF"
Best 12.1 with the gas working backwards :shock:
AllKiller
Post by AllKiller »
Ahh well that 493 will get him in the !!'s or 10's or is it a 535 ....
How big can you go in a 400 block 500 is that the limit??
