Under Kevs Christmas tree
- mopar_mark
- mopar_mark
- Cannonball
kev needs to get his nose to the ground on the pro charger jobbie
get it all set up correcttly,
You ain't wrong there, Fella! All Bananarama! is a bit scary!! Boost referenced fuelling, boost refrenced methanol injection, external oiling, oil splash piston cooling, blow through carb, rollerised roller cam, ally heads etc etc. Steep learning curve! Aiming to build it then dyno it at Sleaths to sort what convertor I'll be using, then shove it in with a Blue/Kev built 727 (steel drum, of course!!) Dana on the back, possibly monoleafs and Caltracs, then I can measure for the prop (1350) and get that sent over from Strange....Aiming to go to Oz end of June early July (Visas came through yesterday!!), so I have my work cut out for me, but hopefully will knock out an unbeatable small block timeslip before I leaveCannonball wrote:kev needs to get his nose to the ground on the pro charger jobbie
