scary message board
AllKiller
Post by AllKiller »
1 thing i did notice is sometimes i add the Emoticons at the end of writing
Before i could add them where i wanted, now it sends them straight to the end of the post regardless.
Is this something to do with the spell check to ?
ALL KILLER NO FILLER
TyreFryer
Post by TyreFryer »
I've never tried adding the emoticons after, I'll disable the spell check and see if it makes a difference, hang on.
Martin Walker
TyreFryer
Post by TyreFryer »
:? Without :? the :? spell :? check enabled...
Yep you can post them anywhere after you type.
Martin Walker
TyreFryer
Post by TyreFryer »
:) And :) if you turn it off :) you can.
Martin Walker
TyreFryer
Post by TyreFryer »
But not if you turn it on :( :( :(
Martin Walker
TyreFryer
Post by TyreFryer »
:D But if you :D uncheck it :D you can post them where you like, but you need to refresh the page after unchecking "Spell check".
Martin Walker
AllKiller
Post by AllKiller »
All ok now....weirdness goin on :thumbright:
It is nearly halloween :shock:
TyreFryer
Post by TyreFryer »
55 minutes to go, make the most of it....
Martin Walker
AllKiller wrote:1 thing i did notice is sometimes i add the Emoticons at the end of writing
I had that a week or so ago, but I think it was only one or two of the emoticons that would jump to the end :scratch:
's ok now tho.
8-[ spooky!
AllKiller
Post by AllKiller »
Are we gonna have a Guy Fawkes / Fireworks next...more fitting on this board i think :thumbright: 8-)
