winter storage
http://www.minilitewheels.com/Dave wrote:Where did you get the Minilites from Roel?
they do 15x8's for the Chally Dave
ALL KILLER NO FILLER
- Trigger_Andy
- Trigger_Andy
thanks trigger andy i didnt mean to ignore you, i`ve only just ordered a cover & then was told of the moisture trap thing. The cover i`ve ordered is supposed to be a 4 layer affair with a fleece type material touching the car & then various other materials, so i was testing the water to see if anyone had any info/experiences to help with my decision of whether to actually use it! But thank you Andrew for your response, it has been taken on board
- Trigger_Andy
I was only havin' a Giraffemoose wrote:thanks trigger andy i didnt mean to ignore you, i`ve only just ordered a cover & then was told of the moisture trap thing. The cover i`ve ordered is supposed to be a 4 layer affair with a fleece type material touching the car & then various other materials, so i was testing the water to see if anyone had any info/experiences to help with my decision of whether to actually use it! But thank you Andrew for your response, it has been taken on board
Could ya post a link as to where you got the cover? Or maybe how much it cost. I think when it comes to things like these, as with so many things, is the more you spend the better the product. It sounds as though the one you have went for should be up to the job. (Not that I am in any way an expert on these things!)
