If the heater hoses are blanked off remove stat or use a restrictor , period.
Ever see a race motor using a stat?
Sounds like a bulk purchase of the NPT fittings for the pump housing!Brutus wrote:You don't wanna know how many cast iron heat exchanger sections i've had to replace over the years , all due to no bypass or the bypass has been isolated.........without water 'circulating' through the block a few cylinders can overheat more than others , a constant flow of water running through the block will limit any hot spots.
Food for thought.
