Posts: 24752 Joined: Sun Apr 18, 04 11:23 pm
Post
by Dave-R » Thu Jun 04, 09 9:00 am
Brutus wrote: 4 bushings , the largest gives an 18* curve ,
I found it was 19 degrees in mine.
Mick
Posts: 3070 Joined: Sun Apr 18, 04 10:55 pm
Post
by Mick » Thu Jun 04, 09 9:57 pm
22 initial seems a lot, i would of thought 18 to 20 would be more than enough.
Post
by Dave-R » Thu Jun 04, 09 10:47 pm
I am finding 18 just enough. It seems to like 19 better but I am still playing with it.
Post
by Anonymous » Fri Jun 05, 09 12:21 am
Mick wrote: 22 initial seems a lot, i would of thought 18 to 20 would be more than enough.
Motors with long durations & tight LSAs will normally require a longer burn time @ idle , some motors run locked out timing , spark lead @ idle is not set in stone , the 605" loves 40* initial/35* total.
Mick
Post
by Mick » Fri Jun 05, 09 12:36 am
What are your cam specs Adam.
Post
by Anonymous » Fri Jun 05, 09 12:44 am
Posts: 22109 Joined: Sun Apr 18, 04 10:49 pm
Post
by Pete » Fri Jun 05, 09 8:01 am
I was running 34 degrees initial (locked out).
Motor loved it - maximum rpm at idle at that setting.
Mick
Post
by Mick » Fri Jun 05, 09 5:28 pm
I'm thinking of going the same route as you, as my cam has more dur than Adam's.
Do you need the starter saver.
Mick
Post
by Dave-R » Fri Jun 05, 09 5:43 pm
More duration @ 50thou than Adams?
What kind of power are you expecting to make Mick?
Post
by Pete » Fri Jun 05, 09 6:57 pm
Absolutely you need the starter saver, but you need to phase the distributor arm correctly or it will kick back if you take too much out.
Post
by Anonymous » Fri Jun 05, 09 7:22 pm
Mick , if you don't want too use a starter saver then fit a switch , crank the motor & hit the switch , no kick back issues.
Switch will interupt the feed to MSD/ballast.
Post
by Pete » Fri Jun 05, 09 7:28 pm
I ran both a retard and a switch. Worked well, until the car went on its roof............
Mick
Post
by Mick » Fri Jun 05, 09 8:06 pm
The motor came with the cam and i know it's too big, when i took it to York the other week, with the 4.56 gear it was going through the lights at 7000 rpm and it was still pulling.
Mick
