upper control arm
Gareth
Post by Gareth »
The best blade we found for the job was an abrasive blade with a diamond grit edge, no teeth. Made by Lennox if I remember correctly. Not cheap though :(
Poor access caused by the inner wings means you'll only be using the tip of the blade. We gradually shortened our blade by removing the tip to make sure we got the most out of it.
Still, one down and three to go, eh Bryan ;)
Burn/melt all rubbers with an accetylene torch , takes seconds.
Mick70RR
Post by Mick70RR »
Brutus wrote:Burn/melt all rubbers with an accetylene torch , takes seconds.
That's what I did.
Gareth
Post by Gareth »
The problem here is that the inner sleeves are rusted to the adjuster bolt. Melting the rubber insert just means it slops around while you're trying to cut it, and everything is covered in goop to make life harder.
Bryan S
Post by Bryan S »
Three bolts down one to go. On the drivers side i've found a nice hole in the top of the chassis and onto the rear mount (what a heap of Bananarama!) :evil:.
On the passenger side one bolt just came out using spanners,surely that can't be right ;) but the other one is going to need cutting out.After that i just need my Bananarama! from Japan :thumbright:
Hey, if i was'nt doing this what else would i be doin?
Bryan S
Post by Bryan S »
