Rocker Shafts
Vintage tractor guys call yank stuff "gas pipe engineering" rugged but crude & simple.
Well of course my rockers ARE offset otherwise they wouldn't line up with the pushrods! #-o
I can't afford new rocker shafts and rockers so I will just have to make do. I will cut a groove in the shafts though. I will make the grooves 20mm long and position them so that they center in the ROCKER and stop 5mm from each side of the rocker.
They are still a good fit on the shafts and I wouldn't even have known there was a problem if I hadn't taken them off so sod it - I will re-use them.
