b7 blue 70 charger as seen at garys picnic NOW SOME PICS
- 70_charger
pics
charger nov 2010 with new wheels fitted
- IMG_0120.JPG (199.44 KiB) Viewed 4687 times
- 70_charger
pics
pic @ santa pod 14/05/2011 8.5x15 rear wheels with bfg tyres and full exhausts
- IMGP0018.JPG (219.67 KiB) Viewed 4684 times
- 70_charger
pics
garys picnic with 10x15 and hoosier quick time tyres
- GarysPicnic2011056.jpg (222.33 KiB) Viewed 4681 times
- 70_charger
pics
garys picnic
- utf-8BSU1HMDEwMTItMjAxMTA1MjgtMTQ1MS5qcGc.jpg (220.92 KiB) Viewed 4677 times
- 70_charger
pics
garys picnic
- utf-8BSU1HMDEwNzEtMjAxMTA1MjktMTA1Ni5qcGc_2.jpg (247 KiB) Viewed 4674 times
So......70_charger wrote:Thanks guys, will post more pics when i work out how to resize pics in iphoto.
The wife is right behind me on getting the charger to run quicker and i have been luck that every time out the mods i have made, got a quicker time, shes normally the one jumping up and down when i run quicker , even thou its only 14sec car
1. Your wife bought you the car!
2. She is behind you in spending dosh and making the car go quicker!
I'd be buying a lottery ticket if i were you........You seem to have struck gold!
- 70_charger
nice car
, nice colour
this vid was posted on here a while back ...
Hi and welcome, a very nice car and a lucky man to have a missus thats behind you like that.
Changing to Auto was a good move for the 1320's, can always go back to stock. I'm sure your having great fun in getting those times down from 15's to mid 13's, everything you do at present will have a major impact on ET's...its quite easy at the mo......however, as you prob know once you start getting into the 12's you have a decision to make as from then on it becomes much harder as you reach the max ET for your car for its p/w ratio and traction capabilities.
If your hunger to go fast remains and you wanna run 10's/11's?, I suggest the easiest and cheapest way to do this without wrecking the car and your pocket will be N20 and a set of Slicks leaving the motor much the same as it is for street driving. You should be able to get at least a second increase with it for no money...to do that on motor you would need a pucker pair of heads to start with and lots of ££££'s!! and weight reduction.
All the best for your future efforts...Les
13 sec is good for a heavy car, i was at the nost nats and the picnic, saw your car run, i wondered why it was loud. If you're going to run open headers, you ought to use collector extensions, they will increase the torque.
BTW It was my birthday on tues, i've got a trip to the cinema to look forward to, so if she's got any sisters you better stick me in the queue as well.
Mick
Mick
- 70_charger
getting ready for mopar nats
well it was running 14's at the pod dragstalgia last weekend due to alternator packing up, i'd just fitted msd and leccy fuel pump so didn't have enough batt power for msd to work right
so i'm fitting new 100amp alternator, bigger battery in the boot
