Metal cutting advice
With a bit of practice you can use these like a surgeons blade
http://www.ebay.co.uk/itm/4-1-2-ANGLE-G ... 23079694b8
1
1
Hi Matt,
If your compressor isn't up for an air grinder use a good quality electric SawsAll.
Make a 2inch cut with the thin disc cutter and use a line of masking tape for a blade guide and saw away merrily!
The steeper the angle you use the saw-blade the more aggressive it will cut.
So use a long blade and use a very shallow angle and use no pressure on da blade.
Always cut near a swage line, that way the remaining panel says strong.
Good luck from Bacca.
as mentioned use a 1mm cutting disc, i usually cut through both panels to get a straight join and then use these http://www.frost.co.uk/intergrip-welding-clamps.html to clamp in place
- weld clamps.jpg (7.12 KiB) Viewed 349 times
Thanks guys for all the fors and against.
Paul that is a lovely looking joint you have there. I have some of those panel clamps, I have not tried them yet as I've always gone the joddled joint route, but following on from everyones advice here, I got some 1mm thick cutting discs and I am going to bite the bullet and try to butt weld the panels.
Its the rear 1/4 panel on the Challenger.
Bacca, Ive done what you said about staying close to a swage line for strength, and have just cut a brand new year one panel in half so I just use the bottom section below the swage.
That took a few deep breaths before cutting into that new panel, very much a clenched buttocks moment!!
Pics when I have something worth showing.
I have a decent joddler with a hole stamp head for plug welding. I have used it for years.Ivor wrote:I would joggle flat panels, drill and plug weld, it easy, it's strong and virtually eliminates warping.
I havent yet cut to butt weld, its overlapped at the moment awaiting alignment and getting the wheelarch well repaired up to where the wing will be.
Perhaps joddle will be better, and thick body seal in the boot to reduce the visibility of the overlap joint.
Don't take this the wrong way Matt, but as your car is what many would call "driver quality"
and you actually use it, I would go with the joggled repair and not worry about the seam showing inside.
As you say, you can Bananarama! it with the "factory look" sound deadening with some textured stonechip and Bob's your uncle.
Matt, nicked that picture of internet, i only butt weld long joints that can be seen both sides, other than that joggling is best, you can get a joggler that also punches out holes for plug welding,
http://www.machinemart.co.uk/shop/produ ... hole-punch
or to save time a air powered one like mine
http://air-tools.co.uk/Product/SY-SA36
are you ready for rear panel, pm me your address and i will get in post to you.
Paul
Paul
- autofetish
Dave wrote:As I advised Will the other day. I really would not try to but weld flat panel areas. Not unless you are very skilled. Curved or rounded areas are not too much problem. But flat panels will weld much easier with an overlap.
And i did listen and try but cut one pannel to short
By the time im finshed i will have so much polly filler in them in cant be good. So i have order so fiber pannels from VFS
They also do rear quaters ??
I thought that was some of your welding on the Chally!74challenger318 wrote:Matt, nicked that picture of internet, i only butt weld long joints that can be seen both sides, other than that joggling is best, you can get a joggler that also punches out holes for plug welding,
Paul
That machine mart tool is exactly the one I have, great bit of kit, had it about 20 years now. I don't think my compressor is up to running tools, only a spray gun really, as its a 50 litre.
Ivor - you are spot on, joddle here we come!
