No. Just splice in an adjustable valve as shown in the Mopar Action article on the link posted earlier. Otherwise the rears will lock up before the fronts. So you have to reduce the pressure going to the rears with the proportioning valve.jerry wrote:Dave can I do away with the metering block and run straight out of the master cylinder to the rear and out of the cylinder to a tee then off to front discs
It helps if you have only 10" drums on the rear. But if you have 11" drums you will need to adjust quite a lot out of them.
