Ahhh, I mean AAR Hood
Les Szabo
Post by Les Szabo »
AllKiller wrote:Les, its not in the car yet been concentrating on getting the Viper Brakes on the car...bit more "Whoa to stop the Go!!"
I wont forget your down for a run in the old girl :thumbright:
All even better things come to those who wait.....a run in a Hemi powered 'Cuda ;)
can I use the N20 as well :lol:
Les
AllKiller
Post by AllKiller »
Not sure what power plant will be in it Les, N2O yes :thumbright:
ALL KILLER NO FILLER
sublimemike
Post by sublimemike »
Are you going to be l using the existing hood hinges Steve?
Looks really good Steve!
Look forward to seeing its progress! 8-)
AllKiller
Post by AllKiller »
sublimemike wrote:Are you going to be l using the existing hood hinges Steve?
Yes Mike...no pin on malarky....not in steel :shock: :help:
AllKiller
Post by AllKiller »
Dave81 wrote:Looks really good Steve!
hopefully more pictures friday Dave :thumbright:
Jon Connolly
Post by Jon Connolly »
Never mind the hood ... I want to see piccies of the altered wheelbase job ... is it still at Gasser Cave ? how`s it looking ????
AllKiller
Post by AllKiller »
Some more pics..... coming on nicely
initial shaped and wired opening
both openings trial fit and shape both wired
for factory finished appearance
Even the inside of the opening will be detailed to look (Better) :oops: than factory ;)
Rear vent is made up of the hood vents removed joined and shortened to fit.....awesome, this bit isnt finished yet and will be detailed and shaped to look as if Ma MOPAR built it.
You can just see where the grilles have been now as if they were never there both sides....fantastic metal work by Mr McCormack...true Metal Guru 8-)
image hosting tiny pic
Adrian Worman
Post by Adrian Worman »
Oh yeah luv the grilles ;)
Jesus built my hot rod
72 Challenger
65 Barracuda
AllKiller
Post by AllKiller »
Ade,
Lance used the Original hood vents in the end as he said they were structurally stronger than the ones you kindly let me have.
..which he thought would work but were not up to it strength wise as he was worried about them bending when painted and I lent on them polishing the car :lol: :roll:
AllKiller
Post by AllKiller »
sublimemike
That's going to be great Steve. A real one off cept for the 1 you modelled it off. I'm looking forward to seeing it finished. Are you going for the black AAR look or stripes when you get ready to paint? What inlet manifold are you going to be running now you got some decent clearence?
AllKiller
Post by AllKiller »
Going to paint it body colour Mike and see how it looks, also doing the AAR rear spoiler body colour too
clean and mean look..I HOPE
same engine and manifold but with a super sucker spacer and more fresh air under the hood should help with lower temps
The stock rallye hood was a bit restrictive I thought, even though i opened up the twin vents for racing...it was hot and very close cleaner to hood clearance
...even without it was only about an 1 1/2 to the top of the carb ...so not optimum :thumbright:
Rogue Trooper
Post by Rogue Trooper »
Hi Steve,
Looking very very nice :thumbright:
How long till paint?
Can you get your Cuda over and sit the hood on it for some extra pics?
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
AllKiller
Post by AllKiller »
Cheers RT,
The scoop is still to be welded in final postion on the Hood ...which is in Brentford and the Cuda in Hampshire....so not for a while
