correct fit?
V8 Sam
- mopar_mark
I had those from an older A body ,I think one of the only other cars that had them were 60s vettes ,not sureV8 Sam wrote:nope there fourpots alright.
I ended up rebuilding them and they still did not work very well so I swaped them out for floating calipers.
And Dave is right ,make sure you use the proper lube for those modern bushes , they will last far longer than stock , and on the LCAS, it is known to drastically improve the handling of the car
VGVIP
Don't know if you have already mentioned it or have it under control but I am surprised that the hose has passed MOT like that. Looks like it has been like it for some time.
Maybe it looks worse in the photo than it is but there has to be a twist in it causing it to be in the wrong place at some point of your suspension and steering travel causing it to make contact with something else.
That would be the first thing on my list to replace.
V8 Sam
correct! it didnt pass! it has now been fixed with a stainless braded type.VGVIP wrote:Don't know if you have already mentioned it or have it under control but I am surprised that the hose has passed MOT like that. Looks like it has been like it for some time.
it was the incorrect hose and was too long, rubbing on the wheel made it wear.
they work ok, the rears locked up for a few breaking attempts after it has been sitting for a few months, but after that it worked fine...well, as fine as a old yank can be!
