I always take the rocker cover off and watch for the intake valve closing. Then kick it a bit at a time to get the timing mark near and fine adjust with the socket.
If I am not confident about the timing mark accuracy I use a piston stop in the spark plug to check that. But no way should you use the starter motor to turn the engine doing that!!
My switch has crocodile clips that just clip onto the relay posts so I can stand at the front of the car and watch everything spinning round in front of me....like a cheap poledancer in a Jean Claude Van Damme film
I dont like all those big scary sparks from my screwdriver
Hi I assume this is a small block, and was the engine ever running if it was what exactly have you done since it last ran?
Also as Mick has said check the reluctor gap (gap between the toothed wheel inside the dizzy and the pick that's in place of the points) just incase you are unsure, best using a brass feeler gauge as its not magnetic. although usually its a bad connection at the connector or broken wire.
*MMA-609*
"Built to be driven!"
It's a longshot, but have you reconnected the dizzy wire connector. Easy to forget when changing out dizzy.
Also, are you sure it has no spark? These cars can take a while for fuel to come up when left unused and feel like it has no spark. That's caught me out before.
I have one of those see through plug connectors that definable shows whether a spark is showing.
That's the thing, I turned the engine over to tdc with the plug out, checked it was pushing/compression stroke and also confirmed with the bottom pulley and a long 1/4 drive extension that it was tdc.
If there is spark and even fuel just pored into the inlet it should fire up.
I have been tweeking the timing slightly, anybody know what it should be? It's a small block 5.2l
I'm waiting for my manual to turn up from the states, I ordered it 11 days a go though so I'm guessing it's been lost..
Back fireing is also a sign of being to lean on the carb
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
