Charger 440 R/T ( work in progress )
- ScottyDave
- ScottyDave
- autofetish
Ive been concentrating on the handling / suspension this week. I stripped the shockers off and replaced them with new uprated units. I also removed the sway bar drop links / the track rod ends / lower knuckle ball joints and replaced them with an hyperflex kit i bought from the USA. The wheels have been balanced and tyre pressures sorted.
I also removed the standard steering box and fitted the "Flaming river" unit along with a new pitman arm. Ive replaced all the suspension bushes which were absolutely shot at with new polyurethane units.
The shockers were way past their sell by date - they were leaking and compressed with minor effort. Prior to replacing everything the car drove like an old truck - it was all over the show. The upgrades have made a BIG difference and i can recommend the Flaming River steering box for sure.
Took the car on a run tonight and really threw it into the bends - OK its no Nissan GTR ( way from it ) but its a lot better than before. Steering is a little heavier when stationary but not as bad as i thought - Happy days
( Next job - Wilwood disc conversion )
My new grill surround arrived this week from the states along with new roof drip rail trim. So I stripped the front end down carefully and pulled the grill / front panel off the car. To access the chrome surround i had to separate the front panel from the grill by removing the rear vacuum pot mounts ( 4 x screws each side ) and then undoing the 20 x 8mm bolts holding the trim to the grill. The original surround was a mess and had little dents all over. The passengers side was also slightly bent. Anyway the new one fits like a glove and has improved the front of the car no end..........
- ScottyDave
Father Christmas came today
Quite impressed with Summit - I ordered this stuff on Tuesday and it was delivered this morning by DHL. Thats damn quick ( thanks for the info btw Dave b )
So this weekend is mostly going to involve .....Stella / Dodge Chargers / scantily clad women in the Hot tub / sunshine / fitting new bits to my motor / bbq and lots of Lynyrd Skynyrd.......can life get any better
