383 Engine Trouble
Craig, FWIW, last Sunday Johns and I were tuning my car. It was too rich at idle and John insisted the floats were too high even at two thirds down the sight window. We wound the floats to the bottom of the window and the motor cleaned right up and the AF guage proved it by the numbers. Worth a look for sure.
John felt that fuel was leaking in at idle and enrich ending the circuit. Maybe that's what you have, plus faulty float needle.
CRAIG
Post by CRAIG »
Sounds like it might be. Never ran 100% scince carb went on. Fingers crosssed should be up and running by end off week
1969 Dodge Charger
1972 Chrysler Hardtop
CRAIG
Post by CRAIG »
1969 Dodge Charger
TW71
Post by TW71 »
Maybe worth checking what power valve is, it maybe a value too close to the vacuum of the motor enriching when it should be closed at idle?
I had this when i changed the cam to a larger one on my 383 which caused low vacuum / washing the bores with fuel :shock:
