carb question
CRAIG
Post by CRAIG »
I only have an advance timing gun
1969 Dodge Charger
1972 Chrysler Hardtop
Carl
Post by Carl »
Yeah thats what you want, your timing light has a dial or buttons to set advance?
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
CRAIG
Post by CRAIG »
Just a dial starting at 0
1969 Dodge Charger
Carl
Post by Carl »
You have a light with a dial similar to this?
Set the dial to 15 that will give you 15 degrees advance when you time the engine with the timing mark on the balancer at TDC mark on the timing cover.[/img]
*MMA-609*
Scooby
Post by Scooby »
Guys vacuum from the distributor ... To carb ...
072
CRAIG
Post by CRAIG »
Would that not make it 15 after tdc or am i being thick. Lol
1969 Dodge Charger
Carl
Post by Carl »
No, by dialling the 15 degrees on the timing light advances the timing, try it, set your timing to TDC and 0 on the light, your mark on the damper is stationery at the TDC mark then dial in 15 degrees you will see the line on the damper move in the advance direction, the timing light does this by changing the phase of the strobe, so now you turn the DIZZY until the timing mark comes back on zero, you have advanced the timing 15 degrees.
Obviously as Scooby said take the vacuum pipe off the carb and plug it whilst setting the timing.
Total advance is another thing that you will need to set at some point but see how you go with this first.
*MMA-609*
Adrian Worman
Post by Adrian Worman »
Just bring it to the Nats in a couple of weeks & at least a dozen eager mma members will do it for ya :lol:
Jesus built my hot rod
72 Challenger
65 Barracuda
charger01
Post by charger01 »
Make sure you remove the flag off the roof. Don't want to upset anyone. :thumbright:
Rebel
Post by Rebel »
charger01 wrote:Maks sure you remove the flag off the roof. Don't want to upset anyone. :thumbright:
No, no,no, leave it where it belongs !
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
