Maybe, but this might explain my problem too;
'The biggest concern with a Torqueflite automatic valve body is the transmission (not the driver) downshifting back into 1st (and this never applies the rear band). In the wrong circumstances this can damage the sprag. Like when lifting and the tires stop spinning, the trans goes into 1st without low band apply (selector in 2 or D), and the driver hits the throttle. Or the tires grip, slip, grip, etc.
Then any time the selector is in "D" or "2" it can go into low gear on its own and the sprag won't hold, allowing overspeed of the front drum.'
From Moparts
Just need time and dollars now
