No spark. Why?
A power wire from battery to positive coil wont work because the orange box wont get power and the dissy pick up wont get a signal.
Put a jumper wire for batt positive to the key side of the ballast resistor.
Eliminate the ballast resistor temporary buy joining the two wires together. Don't leave it like that is the car fires and runs or you'll damage the coil after a while.
- wiring.jpg (47.09 KiB) Viewed 1972 times
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Have you checked the Dizzy???
No spark would possibly suggest an issue here?
rogthedodge
no spark
Miles did you check the reluctor?Had similar problem on Charger .The roll pin holding reluctor in had worked its way out,allowing it to spin on shaft.
do it in a dodge
- mopar_mark
I had the pleasure of staying in the hotel Alfonso in Seville, for just over 6 weeks. Lovely place ...MilesnMiles wrote:Thanks all, currently nowhere near car.
Sat in bed in an apartment in Seville. Which is very nice.
Car can wait
Yep, I'm heading towards the dizzy. I have 12v at the switch side of the ballast. Haven't yet checked if spark coming from the HT lead, that's next.
I did pull the rotar from the dizzy and noted that the knurled trigger piece (forgotten name) rises up the shaft as the rotar is removed, but it's still locked in place with the pin.
