That would make sense,especially if it workedSJH wrote:I think they drill butterfly plates as a last resort on engines with long duration cams and a poor idle. It allows a higher idle speed without moving the throttle stop/ butterfly position hence uncovering too much of the transition slot Otherwise the idle is using the transition slot and there will not be a smooth transition to the main jet.drewcrane wrote:I have also seen drilled butterfly platesmopar_mark wrote: That makes em sinkers
Carb plate looks good in the videos
Shayne
Thompson performance
- rockinpete
Yea it was a stumble that I could not find,I never used an AF meter,but I used a pyrometer , and a vacuum gauge for idle, and also checking the plugs to make sure they are a nice golden brown to get as lean as possible, and the car ran very well at the track at WOT, around town the constant stumble made the carb un streetable with the cam I have , once I tuned the edlebrock,it has much nicer street manners, in the end I intend of installing FI from Fit technology's,or Holly ,,I am about done with carbs, the new FI is really nice and I have spoken to several others one being the road kill show, they drove a 440 charger out here though the desert with out any issues so as funds allow that will be my next thing , this power plate made a huge difference, but I still feel there is power being left on the bench if you will and fi just might be a batter way to get it out of this engineMilesnMiles wrote:Drew, was your a rich or lean off ideal stumble? My Demon has the same and the AF shows it jumps lean and wondering if this item might improve matters.
Yea it is not a problem with all carbs ,just is a cheap way to al least make it more street friendly,I am up to my elbows in a vette tach removal,anybody wanna buy a really nice vette once I get the tach working it is a really nice car, just a PIA to work onMilesnMiles wrote:Cheers Drew, my problem is not so severe, but it does seem aregular issue, the off idle bog. Good luck with the FI.
- rockinpete
Pete,rockinpete wrote:After watching the video I decided to just go ahead and buy one, it arrived yesterday and took ten minuets to fit. The plate does exactly what it shows in the video and make the engine run very smoothly in the garage.
Yet to try it on the road
It took you only 10 mins to fit - did you fully remove your carb' and do it on a workbench, or just do it in-situ'?
Still need to fit mine.....
