Weird wheel toe-in after tie-rod end change
Yes I've heard it a million times too along with Carrots help you see in the dark and that ain't right either :lol: To be fair, the old count the turns method will at least get you within the range of the tracking gauge so it has some relevance.
already been said
aha
you aint seen me
Garp
Post by Garp »
Thanks all - sorted, and now that' it all straightened out, I can even feel the benefit of the new tie-rod ends on the steering. A full 4 turns loose on each.
Will take and get it properly sorted this week.
Thankful for all you knowledgable folks on here. :thumbright:
My Bee is set at 3 degrees caster, .5 degree positive camber and .5 degree toe in.
Total pot luck, you normally cannot get that much Caster on a stock set up.
Toe in / out has a very big impact on the rest of the geometry. Surprising but true.
