Last Wednesday of the month at The Crocodile EN8 9NQ
Re: September meet in October
Its tonight folks ..............and strangely it isn't raining
Roy (Slowhand) MOCGB Chairman
Good to meet you yesterday evening Ross - hope you got back OK?
I MUST get down to this one day, it's about 1/4 Mile from where I work!
....and you could cover that quite quicklyPete wrote: Thu Oct 05, 17 8:24 am I MUST get down to this one day, it's about 1/4 Mile from where I work!
Also a 1/4 mile from where I live
Hi Roy
Good to meet you all to, limped home and as I got in my road a lot of steam was coming out of the engine bay! Reversed it on the drive and there was a pop and I found the breather in the valve cover was the reason for the pop as it had ejected itself, I'm assuming some sort of back pressure as the leaking coolant pipe had finally given up and was spraying coolant out at high velocity & hissing like a snake!
Hopefully the fact it was till spraying out coolant would suggest I have completely cooked the engine, but I'll change the pipe at the weekend, fill it with coolant and hope for the best!
Glad you made it home Ross even if it was a 'Thomas the Tank Engine' style arrival
Pretty good turn out (with 10 mustangs of various years, two Hellcats, one TransAm and your Dart.) considering that winter is coming.
Next one at The Crocodile is back to the normal "Last Wednesday" format so 25th October..... probably be dark at 4.00pm by then
Re: October meet....strangely in October
As above - the next get together at The Crocodile (in Cheshunt, Herts) is on Weds. evening 25th October. See ya there?
Wednesday 30th May
OK....winter is officially over
Last Wednesday of the month at "The Crocodile" should be back on track. C'mon help make it interesting!!
Re: Last Wednesday of the month at The Crocodile EN8 9NQ
This Wednesday folks!
Got a busy week but I'm trying to schedule that in...
Maybe...
I suppose our chairman might even make it.... and boost the number of Chevys there
Thanks for coming guys - Nice to see a good mix of Yank cars at The Croc last night
Yes a good mix.... well, we added a couple of non-Mustangs to the mix...Slowhand wrote: Thu Jun 28, 18 7:45 am Thanks for coming guys - Nice to see a good mix of Yank cars at The Croc last night![]()
Good to catch up with Les Szabo, Steve Rawlings and Graham Barrs tho, in addition to the more recently acquired car chums...
My fave was your 'new' 69 tho Roy, fantastic
- P1090572.JPG (135.19 KiB) Viewed 1808 times
- P1090573.JPG (120.51 KiB) Viewed 1808 times
- P1090574.JPG (130.52 KiB) Viewed 1808 times
- P1090575.JPG (105.46 KiB) Viewed 1808 times
- P1090576.JPG (132.74 KiB) Viewed 1808 times
- P1090577.JPG (118.41 KiB) Viewed 1808 times
- P1090578.JPG (108.41 KiB) Viewed 1808 times
- P1090579.JPG (91.39 KiB) Viewed 1808 times
- P1090580.JPG (112.46 KiB) Viewed 1808 times
- P1090581.JPG (102.54 KiB) Viewed 1808 times
- P1090582.JPG (111.85 KiB) Viewed 1808 times
- P1090583.JPG (100.33 KiB) Viewed 1808 times
- P1090584.JPG (114.73 KiB) Viewed 1808 times
- P1090585.JPG (137.78 KiB) Viewed 1808 times
- P1090588.JPG (109.17 KiB) Viewed 1808 times
- Cannonball
RobTwin wrote: Thu Jun 28, 18 8:21 amYes a good mix.... well, we added a couple of non-Mustangs to the mix...Slowhand wrote: Thu Jun 28, 18 7:45 am Thanks for coming guys - Nice to see a good mix of Yank cars at The Croc last night![]()
My fave was your 'new' 69 tho Roy, fantastic![]()
Did Les mention he once ran a 990 on an old sixpack mtr with a tidgy bit of sniff Rob ??????
