My 73 Barracuda build
- ScottyDave
Re: My 73 Barracuda build
Yes, I love seeing them 'come back from the dead' like this, great job
amazing work
a true resurrection. its gonna be great when done... better than new.
Fantastic work, that hood looks a devil to fit, makes the Challenger look easy as it only meets at the sides.
Excellent progress, you should be very proud.
- Russ1971scamp
fantastic work, such skill
Wow, very impressive work. Looking forward to seeing the progress.
Brilliant job, another one saved and brought back from the dead. Great work, another project with some serious talent behind it
- Cuda Commando
Just come across your project reports. Really interesting seeing how your long hours and skilled work is taking shape.Keep up the good work and reports, all the long hours of toil will be worth it when you are behind the wheel and cruising down the road.
Chargingatchya
Awesome post and amazing work. Is it not crazy what we do to drive these cars?! So so worth it though. What a beautiful machine you are building. Well done!
Tommy2turbos
Not much in the way of updates at the moment. I've managed to get the 4speed tunnel mounted and welded in place, and the parts for the transmission finally arrived. Dan at Brewers performance was incredibly helpful with sourcing a bell housing and the necessary hardware to get it mounted. I'm still waiting on a few parts for the clutch linkage but there's stills plenty to do before it all goes together.
The boot floor is 99% complete but the rear quarters and rear valance are still taking a while for me to get to a point I'm happy with. There's been a lot of cutting, trimming and panel beating to get the gaps nice and even but with so many different panels having been replaced, you can imagine, it's very time consuming getting it all to a point I'm happy with.
Still, some progress is better than no progress right?
- DSC_1124.JPG (259 KiB) Viewed 6637 times
- DSC_1126.JPG (273.78 KiB) Viewed 6637 times
- DSC_1163.JPG (263.51 KiB) Viewed 6637 times
- DSC_1127.JPG (286.17 KiB) Viewed 6637 times
- DSC_1491.JPG (285.16 KiB) Viewed 6637 times
Excellent work, please keep the updates coming.
For the record, I am going in the opposite direction on my 'Cuda: Taking the 4 speed out and putting an auto in!
- ScottyDave
Tommy2turbos
Thanks for the support guys, it's great to be part of a community that's supportive
Over the last couple of weekends I've managed to prime the interior of the car. I used a zinc based etch primer by Bonda. it covered really well by using 2 light dust coats and a final wet coat diluted with approximately 10% cellulose thinner. Hopefully this will help the old girl last another 40+ years.
I've also modified the rear bumper brackets to neatly tuck the bumper in to the recess and remove the old plastic filler panel's. I had to remove over 40mm out of the bracket's to get the gaps neat. I elongated the fixings all around to give me some adjustment to ensure even spacing when it comes to final fitting too.
Next on the agenda is to get the rear springs relocated inboard to fit some wider rubber under the arches.
- DSC_1518.JPG (274.28 KiB) Viewed 6547 times
- DSC_1532.JPG (248.29 KiB) Viewed 6547 times
- DSC_1530.JPG (257.75 KiB) Viewed 6547 times
- DSC_1549.JPG (252.02 KiB) Viewed 6547 times
- DSC_1558.JPG (271.77 KiB) Viewed 6547 times
- DSC_1567.JPG (261.53 KiB) Viewed 6547 times
- DSC_1570.JPG (253.47 KiB) Viewed 6547 times
Much neater on the rear end, excellent work!
great work
