Cheers Steve
E10 petrol
Re: E10 petrol
Very interesting Matt....lots of useful info on this subject there. Thanks for posting it
Cheers Steve
Cheers Steve
Re: E10 petrol
Thought I’d mention that I filled the Dart with E10 yesterday… it was almost out of fuel and what with all the HooHaa at the petrol stations I’ve been unable to find any fuel.. finally found a station with some but they only had E10… I thought one tank won’t be a problem… how wrong I was, car absolutely stinks, think it’s running very lean, temp stayed pretty normal and engine fired ok but the smell was horrific. At first I thought there was a leak on the carb or fuel line but it’s just the fuel I think… anyway I’ll be getting through the tank as fast as I can so I can fill up with premium at the first chance I get. Makes me wonder if the car was running very me to lean before the E10? Anyway thought I’d share.
Pimps in the Front
Hoes in the Back
Chumps in the Trunk
68 Dart Post
Hoes in the Back
Chumps in the Trunk
68 Dart Post
Re: E10 petrol
Mine’s running better than it’s ever done on the ethanol free Esso 99 premium. Definitely noticed a difference over E5, smoother and more responsive. E10 won’t be going in the tank.
Re: E10 petrol
Is Esso 99 Premium still ethanol free? My wife filled up her beetle recently and said that E5 is now marked on the pump in brackets where it wasn't previously.Mark B wrote: Sun Oct 10, 21 4:45 pm Mine’s running better than it’s ever done on the ethanol free Esso 99 premium. Definitely noticed a difference over E5, smoother and more responsive. E10 won’t be going in the tank.
Re: E10 petrol
They have to put E5 on pump, but it’s ethanol free. Except in Cornwall for some reason.Matt74 wrote: Sun Oct 10, 21 10:12 pmIs Esso 99 Premium still ethanol free? My wife filled up her beetle recently and said that E5 is now marked on the pump in brackets where it wasn't previously.Mark B wrote: Sun Oct 10, 21 4:45 pm Mine’s running better than it’s ever done on the ethanol free Esso 99 premium. Definitely noticed a difference over E5, smoother and more responsive. E10 won’t be going in the tank.
Re: E10 petrol
Mark B wrote: Sun Oct 10, 21 10:37 pmThey have to put E5 on pump, but it’s ethanol free. Except in Cornwall for some reason.Matt74 wrote: Sun Oct 10, 21 10:12 pmIs Esso 99 Premium still ethanol free? My wife filled up her beetle recently and said that E5 is now marked on the pump in brackets where it wasn't previously.Mark B wrote: Sun Oct 10, 21 4:45 pm Mine’s running better than it’s ever done on the ethanol free Esso 99 premium. Definitely noticed a difference over E5, smoother and more responsive. E10 won’t be going in the tank.
Re: E10 petrol
That's interesting. I put E10 in the Challenger as that was all there was. Still drove Ok but I did notice a petrol smell when parked which I don't usually get.lough3969 wrote: Sun Oct 10, 21 4:24 pm Thought I’d mention that I filled the Dart with E10 yesterday… it was almost out of fuel and what with all the HooHaa at the petrol stations I’ve been unable to find any fuel.. finally found a station with some but they only had E10… I thought one tank won’t be a problem… how wrong I was, car absolutely stinks, think it’s running very lean, temp stayed pretty normal and engine fired ok but the smell was horrific. At first I thought there was a leak on the carb or fuel line but it’s just the fuel I think… anyway I’ll be getting through the tank as fast as I can so I can fill up with premium at the first chance I get. Makes me wonder if the car was running very me to lean before the E10? Anyway thought I’d share.
- Gas for GOSH
Re: E10 petrol
Mark where did you find out that it’s not ethanol free in Cornwall? What is the reasoning for that!?
Re: E10 petrol
Hi Simon, I looked into this when I read Mark's post last week and found that reference on the Esso website:Gas for GOSH wrote: Fri Oct 15, 21 10:37 pm Mark where did you find out that it’s not ethanol free in Cornwall? What is the reasoning for that!?
https://www.esso.co.uk/en-gb/fuels/petrol
Doesn't say why tho
- mopar_mark
Re: E10 petrol
Re: E10 petrol
Bit slow, as Rob said. Due to technical reason, what ever that is. So looks like your Esso premium isn't ethanol free in your area.Gas for GOSH wrote: Fri Oct 15, 21 10:37 pm Mark where did you find out that it’s not ethanol free in Cornwall? What is the reasoning for that!?
Re: E10 petrol
Well it seems that my '96 2L zetec Mondeo doesn't like E10. It always kangaroo'd a bit the same as my previous Mondeo did but has gradually been getting worse over the past couple of weeks since using only E10.
Gonna drive further to fill up at Esso and see if it improves.
It could be another fault but funny it's happened now after using E10
Re: E10 petrol
i had similar years ago with an Alfa 156
ran well enough on esso ran badly on shell fulesave 95 the engine check light used to come on....
i was pretty certain it was the fuel until my 02 sensors died
the reason they died was eventually traced to a head gasket problem
which only became apparent when it got so bad it would not turn over and start....
but being an alfa the ODB2 was basically telling me i had faults with everything including the airbags
a great but truely anoying car.
No I wouldn't
i guess if everything is slightly off a change in fuel will highlight that all is not well....the fuel didn't cause he head gasket problem i think it just tried to highlight it
No I wouldn't
Re: E10 petrol
I've had an issue with my A100 van recently after filling up a couple of times with E10.
The stuff perished the glue that holds the paper fuel filter inside the clear plastic canister. I ended up with bits of rubbery glue inside the float bowls and sticking float valves.
It's now got half a tank of E5 and a new fuel filter but still haven't been able to get the thing running since.....but thats another story
if you don't learn from your mistakes then they are just mistakes !
Re: E10 petrol
I've just found out that one of our local independent forecourts sells all E0 fuel, Win
