Adjustable Pinion Snubbers?
TrevD
Post by TrevD »
shame he has no pics, i couldnt make one for that (my material costs would be more :oops: )
Does sound cheap that!
Praps its just an ally post wedged between the axle & the floor pan :shock:
The one you got Kev is $79.95 from Mancinis & $74.99 from MagnumHP.
Still sounds cheaper than making one, but the dreaded shipping/duty/tax will prob put the mockers on that.
Also thinking of one of them fancy driveshaft loops, not keen on the colour tho! http://www.magnumhp.com/drivesusp.php#
Reckon they could be made for way less than $150. Ok, maybe not quite as pretty but could be just as functional.
Thanks for the tech on the angle Kev. Had to do a bit of extra homework on the old interweb, and found this http://www.carcraft.com/howto/91758/, some good info to back up your explanation ;)
My floor pan's got a reinforcement lump from the factory, or is that standard and it cracks anyway?
Basic mopars didn't always get that Kev.
MrNorm
Post by MrNorm »
Mine had the factory reinforcement but I added some more to make sure!!
Snubber hump and hi-tech spring clamps for Dave! :D Also a pic showing the box into frame rail mod.
What I was after Kev was suff like minimum thickness steel for the clamps and size/grade of bolt. I do know how to bolt two bits of metal together. :roll:
I'm suprised you haven't tried the old electrical tape method Kev? :lol:
Glad that Northern Engineering isn't completely dead, Dave :D
4"x1.2"x0.35" bar with 0.5" L grade bolts held with Nyloc-nuts so as not to bend the clamps. In 4 yrs of running them I've had one loosen off after about 400 miles. HTH! 8-)
Actually. Thinking about it clearly. I am not sure I would have the clearence between spring and tyre to do that. I will have to check.
It might have to be a roll of gaffer tape after all. :D
