Look here first!
Dave999's link from another thread on gear setup.
http://supahonkey.com/offroading/jeep/Gear%20Setup/
Dave (Corvette's) link on valve body Great info
http://www.forabodiesonly.com/mopar/sho ... php?t=2167
I think the link was first poted on here years ago by Blue? He has probably been on that forum quite a lot over the years. :read2: :thumbright:
Steve wrote:Just been reading a thread on a US site where a guy was having no end of problems sealing his transmission pan. Having tried numerous products, he had total success using the below gasket.... May save us a few headaches if this problem crops up!
Cheers Steve
http://m.summitracing.com/parts/MOR-93110
MilesnMiles wrote:M
Nicked from FABO, might be useful. Includes dimensions etc
http://www.forbbodiesonly.com/moparforu ... ansmission
Dana manual prop alignment
db wrote:http://www.how-to-build-hotrods.com/dri ... angle.html
Lots of good techy stuff on this site :thumbright:
Dave wrote:I go by this little drawing.
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 911f25.jpg" border="0" alt=" photo imagesXV56Q162_zps39911f25.jpg"></a>
727 gearbox
The front port is the oil from the converter out going to the cooler, and the rear port is the return from the cooler going in to the lube circuit.
Size of thread in gearbox casing is 1/8 NPT
The factory oil lines are 5&#8260;16-inch pipe
If you ever have the box apart, drill a 2mm hole through the case just inside of that rear return port from the cooler. This will oil the back of the overrunning clutch, keeping it cooler and stopping it from wearing into the back of the case.
If the overrunning clutch ever fails your transmission will explode.
