Tuning questions
- Dave-R
True but...you will normally find that when the mixture starts to get ballpark the exhaust temp will settle down around 800-850 degrees. So I am told.Mick70RR wrote:Beginning to think this O2 sensor is pretty useless without measuring the temperature unless you are aiming for 14.7:1. 850mV would be 14.4:1 at 500 deg C but 11.5:1 at 900 deg C.
Then again you can now get these wideband versions (more expensive) that are a lot more accurate. Esp in the richer than 14:1 band.
These tools are not perfect but they get you a lot closer than any other way. After that it is still down to experiance and trial and error untill you feel it is right and the plugs/strip times confirm it is right.
Almost every yank car i have ever tuned has been too rich on the primaries.
