489 case
Do the bits that will give you the most for the least first and on that little list electronic ignition would be the first.
Where's the sence thinking about a diff with a bigger gear if you're still on points, I take it it's still on points?
The convertor, gear and tyre need to match the cam, the cam needs to work with the rest of the motor, the motor also needs to stay in one peice
