1968 Valiant SB 9.844 @ 134.04 - Now retired
What RPM @ 124 MPH? , with a 29" tyre & 4:56s around 7k? , gotta love those lil ole small blocks 8-)
Jon Connolly
Post by Jon Connolly »
Yep
Bang on 7000, had a 7000 chip in there and took it all the way, was shifting at 6500
28" tyre so I do need to change the gears but didn`t have time before weekend. I already have 4 11 which in theory should give a top speed of circa 130 mph
I do not trust these " online " calculators though and prefer to do things by trial and error ... 1 modification at a time
DaveB
Post by DaveB »
Well done Jon,told you it would make that blower motor look gay ;)
Well done Jon, those limiters drop cylinders early so you may need to turn that up a bit ;)
Good to see you at Shakey, at least you weren't in a Beetle ;) ;) ;) ;) ;) :thumbright:
8-) 8-) 8-)
Very well done Jon, top result for a top bloke! :thumbright:
68valiant
Post by 68valiant »
Congratulations Jon, In the 10's!
I want to get there eventually with my 408ci valiant so its good to see it can be done!
Jon Connolly
THANKS FOR ALL THE KIND COMMENTS AND ENCOURAGEMENT
It does make a difference and helps during those moments when you seem to be going backwards with the project.
Next stage is a new lightweight Kirkey seat and mounting frame, roll cage padding, 4 11 ring and pinion and replace the Detroit Locker with a Eaton Truetrac
Then out again onJjune 18th for final testing and set up
:read2:
Stick a spool in and save 50lbs :thumbright:
Boz01
Post by Boz01 »
Well Done Jon! :thumbright:
'You can never go fast enough!'
1966 Dodge Coronet 440 c.i.
1969 Dodge Dart Custom
http://www.americansuperstock.co.uk/
Jon Connolly
Just doing the final few bits and bobs to save weight
1 - Wilwood rear drum to disc conversion
2 - Detroit Locker to aloooooominum spool
3 - Mini starter
This lot should see approx 60 lbs weight reduction and get the car around 2300 lbs without driver
Also making a torque strap
I would have thought the drums were lighter than the Wilwood disk conversion...but what do I know of all this new technology?
Next you'll be drilling holes in the glass! :D
Jon Connolly
Glass went long ago Ivor
:shock:
Small slant 6 drums work well. They do not drag like discs do.
They just don't stop the car as well as discs do (should).
Right, it's out with the hole saw on the body then Jon...slant six drums...I have a set of those and they are going in favour of disks...evenb if they are a bit heavier...
