I have a fish story
I finally got the window trim done, I did not use the factory stuff, mainly because I like the look of the rubber trim ,it came out nice on the front , but the back required small slits to accommodate the radius, all in all it came out great and I can live with it.
I also perfected the badge resto, I found some on E bay, and they are very hard to find ,I got lucky, and have some extras now. Lisa does not like it on the fender, and I agree I am not in to labels, I taped it on to see what it looked like ,looks ok ,and on the key hider it is cool there but we like the clean look.
- r.jpg (131.25 KiB) Viewed 2996 times
- P1020527 r.jpg (140.35 KiB) Viewed 2996 times
- P1020521 r.jpg (145.85 KiB) Viewed 2996 times
- P1020529 r.jpg (98.71 KiB) Viewed 2993 times
- mopar_mark
Satin Black would be my choice, but its good to be different & as per original.
Not sure about the badge on the front fender, then again, I have never seen a GC car before you showed yours.
Windows look great, paint is so nice & shiney its hard to see
- Cannonball
I LIKE THE REAR END TREATMENT BUT WOULD ALSO PAINT THE LIGHT SURROUNDS TO SUIT, OH AND ALSO LACQUER IT,
It is from a dodge Dakota , not sure what year, but I am having second thoughts on the rear, the front screen looks great the cuts are ugly and I will lost likely change it our with the factory stuff, I have it but it has hail damage and will require some work,so I learned alot, but might change itBlue wrote:I like the argent rear panel! I really like that rubber screen trim, where did you get that from? Wouldn't mind doing the Valiant like that.
Finally got the GC rocker molding on, makes the car look a bit different.
I had to search for the nylon clips, and modified them, and also used jack nuts for the ends.
- P1020550 R.jpg (141.86 KiB) Viewed 2908 times
- P1020545 R.jpg (106.39 KiB) Viewed 2908 times
- P1020544 R.jpg (159.7 KiB) Viewed 2908 times
- P1020542 R.jpg (159.44 KiB) Viewed 2908 times
- mopar_mark
