Mega block
Cannonball wrote:
i think it will be the oil, and maybe the oil pump relief spring needs a tweek
Will post up when i do the oil change.
Hey Brutus,
Not sure what pump your running, but got a big selection of new different rated springs which I use in my KB pump if any good to you. I had the opposite problem to you, too much pressure, so ended up changing springs till I got a number I was happy with.
If it were me & assuming you can easily pre oil the valve train. I momentarily restrict the oil supply to the spray bars, give the valve train a liberal dose of hose from an oil can & fire the motor.
The should be sufficient oil getting to the top of the motor, plus what you added from the can. You don't need to run the motor long to see if the oil pressure shoots up. I had to run a restrictor with my spray bar set up, in fact I used an adj regulator from work, so could easily turn to my desired flow & lock it up.
Ok here it turn up your volume and suck it in :thumbright:
Top Bananas!!! 8-) 8-) 8-) When's the first RWYB????? Loving the porn soundtrack, Bob :thumbright:
GTXJim
Post by GTXJim »
Excellent sounds the nuts well done :thumbright: :thumbright: :thumbright:
Hell Yeah!! I'm a Redneck
Congrats 'The London Mob' :thumbright:
I'll have to wait I get home tho to comment on the sound (no sound here at work) :roll:
If it sounds half as hard as you lot look in the vid, we're all in for a treat :D
Sound
Bah ba bup bah bar dup doodle doodle de dup :D
steveo
Post by steveo »
awesome stuff :thumbright: =P~ :pentacool:
Re: Sound
Knightcharger wrote:Bah ba bup bah bar dup doodle doodle de dup :D
Sounds like it's missing on No 7 :-k
:lol:
Scooby
Post by Scooby »
Adam awsome mate well done to all.
Rich.
072
Scooby
Post by Scooby »
Upps twice sorry mods please delete.
R.
072
It looks and sounds a real beast now. =P~ :thumbright:
Lookin forward to seeing it at the pub this Wed :thumbright: ;)
:help:
sounds good mate :thumbright: :thumbright:
