RedRavens 1970 Dodge Challenger R/T 383 Magnum
Are you driving the MOPARS over??
mo_malone wrote:Were leaving Dublin port at 8.30 fri morn, we land in holyhead at 11.45 and it takes about 4 1/2 hours to the pod, this i our first year drivin over so cant really say what itll be like to get there, well see what happens!
Were coming back on the sunday night the boat is at 2.30am on mon morn so a long night land back in dublin bout 5ish.
Dont think there will be any bother gettin on the boat now only a spot for one of the lads the other day![]()
See what you can do![]()
Later Mo.
Oi....."Dun Suas Mo Chara" Ha Ha.....
I doubt I will be bring my Challenger dude, Unless Year One deliver by Concorde before Friday!!!
Getting all worked up about it....sounds like really great craic
Can you pick up parts easy enough aswell at Santa Pod Dave??
Dave wrote:You can smell it on my breath for days after though.Clivey wrote:Nice to see a bit a Gaelic being used![]()
RedRaven. Of course you have to bring your car? What are you thinking of?
The distance is about the same I have to do. And I bet yours does more MPG than mine.
Cant beat a few gealic mushrooms
RedRaven, what are you waitin on, is the car driving? Will AKA Neil is the man for parts, just send him a line and he'll get you what you need.
If you had ordered the bits from summit yesterday you'd have had them on wed or thurs, if its only service bits your looking for try match bits up in southside motor factors, steven, mark or ger will help if they can.
This is what I have ordered from Year One...
Im having problems with my Ignition so I wouldnt try for Santa Pod unless I get this sorted!!
Ballast resistor for 1956-1971 Chrysler models with point-type engine.
Vacuum pump and brake bleeder kit.
Remote starter switch.
Starter relay, all 1966-1974 models except 1966-1969 M/T models, aftermarket.
Fel-Pro performance cover gasket for B-body: 1965-1966 361, 1964-1971 383, 1972-1974 400, 1964-1965 426 Wedge, and 1967-1974 440 V8 models. E-body: 1970-1971 383 and 1970-1971 440 V8 models.
Fel-Pro exhaust manifold gasket pair for B-body: 1965-1966 361, 1964-1971 383, 1972-1974 400, 1964-1965 426 Wedge, and 1967-1974 440 V8 models. E-body: 1970-1971 383 and 1970-1971 440 V8 models.
Oil pan gasket, fits all big-block and 426 Hemi engines, aftermarket.
Brake shoes for 1969-1975 B-body models, and 1970-1974 E -body models all with 10" x 2-1/2" brakes.
Wiper blade for pin-type wiper arm fits 1970-1974 Challenger models, aftermarket.
Plus a set of Mopar performance Valve Covers
A Magnetic emergency drain plug
and a steering wheel lock plate remover
mo_malone wrote:Dave wrote:You can smell it on my breath for days after though.Clivey wrote:Nice to see a bit a Gaelic being used![]()
Cant beat a few gealic mushrooms![]()
- Dave-R
Mostly stuff you could have got cheaper and faster at Summit Racing. I did tell you only to use Year One as a last resort as they are more expensive than everyone else.
Sixpack Speedshop will be there. They are bringing stuff people order so you can pick it up. I am after a new trunk mat for my Chally and at 65 Euros all in from them it is not a bad price.
Well Im waiting to hear back from them on one or two things and they told me they wouldnt proceed with the order until I tell em...
What from that list would you say they would have at Santa Pod Dave??
Dave wrote:Mostly stuff you could have got cheaper and faster at Summit Racing. I did tell you only to use Year One as a last resort as they are more expensive than everyone else.![]()
Ha Ha....Ive stripped the old valve gaskets off, they were welded on...I can only start the car from under the hood and I have to hold the key in the start position in order for it to keep running, when I let go and the key returns to the run position the engine cuts out...I dont fancy holding the key in the start position all the way to Santa Pod!!!
And thats provided everything else is ok...I wont want to hold you guys up..nor do I fancy being stuck in the at the side of the road in the U.K.!!!
mo_malone wrote:I have a ballast resistor at home and a spare coil, got new one from summit "mopar performance" coil kit with the bits $35, dont mind the rest just top it up with oil and it'll be fine.
You can do the rest when you get back, its a long year to wait for the mopar nats again ask anyone here!
