Cut the plug up today , fuel ring half way up porcelane
Last time i ran with the nitrous i was using 97 in the tank & C14 in the cell , with that set up i pulled 10* , the porcelane showing pig rich & the ground strap showing a heat line just @ the tip , telling me again to add more timing &/or take out some FP.
Yesterday i was feeding the nitrous & the carb with C14 , also pulling 10* on a two50 shot , if i had more track time would of ended up maybe pulling only 4/6* &/or removing 3/4/1lb fuel pressure , as i would of prefered to run it lean as opposed to rich.......should of given me just what i needed.(ETs)
NEED MORE TIME TO DIAL IT IN.
Gonna hop on to the yankie site for some info.
