one rear brake getting too hot
be careful continuing to use the car whilst you have this issue, a couple of years ago i had a rear tyre explode on a 61 Cadillac i had just purchased because the rear shoes were fitted wrong by the previous owner and dragging, melted the rubber caps on the wheel cylinder and removed all the material from the shoes,
im really sympathising with you on this Miles....I thought mine were fixed until I went out last night. 5 up...30 miles or so and both rears smoking again!!!
Had a look this morning....backed both right off and started again. Adjusted up so not touching at all on jack and wheels spin freely. Went out....braking poor and warning light on. Wheels off again...adjusted out more till brakes work but dont bind. Another run..one hot....one cold. Light not on. Adjusted hot one back off....cwaited till cool...run...both hot again!!!! Like you....rolls fine...parking brake not binding.
They work and MOT tomorrow so will just have to cross fingers and have anither look at the weekend
Cheers Steve
Cheers Steve
Cheers Steve
Cheers Steve
Steve, best of luck with it all.
I'm wondering about the bearings, but i think brakes more likely.
Just about everything local to the brakes is new including wheel cylinders, hardware, the brake lines and union on top of the axle, new axle bearings and rebuilt diff etc.
It's all pretty spotless.
Just a thought, but how hot should brakes be after a thrash with plenty of braking not to mention the shuffle down my narrow drive?
Nothing smoking on the brakes. The front discs are cooler (wheel is warm to the touch), but they are exposed to the air more than the drums
Nope.
I had a rear hose collapse internally - no outward signs.
In my case I could take the rear drums off, run the motor with a Servo, stand on the brakes and the rear pistons would not move.
If you are CERTAIN that there are no installation issues and the brake fluid is new, then you have to work through on a process of elimination.
Changing the rear hose may be the next logical step...
Mind you, if ONLY One rear brake is getting hot, it points to incorrect instalaltion / Drum out of round / some other issue yet to be identified.
takes a while for your mighty hot drum to transfer its inner warmth to the wheel??MilesnMiles wrote:OK mate, but in principle we mean the same thing in that it acts on the adjuster that pushes on the brake shoes.
Here's a thing for your science head related to the above.
Went for 20 mile thrash on new carb last night. Lots of braking etc..
came back turned car off and decided to check the heat of the offending brake/wheel. Suprised to feel that it seemed less hot than before.
Went indoors for five minutes to open celebratory beer or so, came back and touched the same wheel and now its really hot! What have i not learned yet???
just back em off a bit when hot and binding and go for a drive with out doing much brakeing to cool them off
if no better
maybe you do have a collapsing pipe or one side of you wheel cylinder is sticking but they are new so they shouldn't do that
tend to get that when you put new shoes into a car thats stood and move the seals in the cylinder into an area previoulsy un swept since 1976 hence its a bit corrdoded
heres a little ploy that might help and will keep you occupied on a summers evening
you need
1 vandals marker permenant and fat RED or Green would be good black you won't see
1 pot of nail varnish or paint (rampant fucsia or hemi ornage)
1 pot of tippex (tippex or liquid paper, don't sniff)
on each shoe
draw 3 lines one of each kind of stuff at the top end, 3 lines in the middle and 3 lines at the bottom
close together across the face of the shoe (i.e on the friction surface
the marker sinks in
the paint or varnish sinks in and sits proud
the tippex mainly sits proud
so one of them will wear away quicker than the next which will go quicker than the pen
do front and back shoe
drive for 1/2 an hour
and pull off hub
appriase the lines you drew
if you are lucky and something is left to see
this will indicate which bit of each shoe you are using
ends worn and the middle still there the shoes are of different curvature to the drums and will eventually bed in....run them out of adjustmnet or take off a bit of the depth of the friction surface at each end so the midddle actually hits the drum (wear a mask)
1 shoe nothing left the other shoe untouched indciates sticking wheel cylinder
OR
the shoe pad (flat areas where side of shoe backing rubs) on the backing plate have such a groove worn in them that the shoe isn't moving or is moving and getting stuck on the ridge and not returning
pull off shoe and file smooth the flat pads (if really bad they need welding to build up) on the backing plate. Then cover with a tiny smidge of copper slip the turned over edge of the shoe backing and the area it sits on on the backing plate that you just filed flat.
if the backing plates have been stove enammelled plastic coated or painted with thick gloopy hammerite the coating could be causing the issue. file/sand it off on the pads the copper slip will stop corrosion
do the thing with the lines of paint and pen again to see you have it working
bit of a faff but it might just work
Of course i haven't tried it...... too much like hard work
easeir to say than do.
dave
you need
on each shoe
the marker sinks in
and pull off hub
OR
dave
Dave, stretch and challenge
love yer work. But this evening I spent some while checking E brake release (it does) and getting my son to depress brake pedal whilst I watched various parts move. They did. At one point I thought the cross strut below the wheel cylinder wasnt returning correctly, but it was.
Got bored and wanted to drive. Did a quick 5 mile route involving just light braking to get fuel and some miles later pull into a lay by. Brakes were cool.
Did some honing, used lots of brakes around town and then they got hot. Not mental, just a bit hot to touch.
Maybe it's all new and just needs to bed in!
