Post up your Cars 1/4 mile ET's Combo
More modest stuff
74 Dart Sport - full weight
360 motor with hi comp pistons, XE268 cam, air gap, 670 Holley
2,800 stall, 3.23 gears
stock tyres and no traction
14.09@97mph
shovelheadrob
Post by shovelheadrob »
My old '69 GTS Dart (now Mick's) no idea on the weight
340 sb 10.5 compression, forged pistons
284/484 mopar performance hyd cam
Stock heads, gasket matched by myself
780 vac sec Holley
4 speed
8 3/4 with 3.91 gears
Can't remember what tyres but treaded street anyway
12.91 @ 102 IIRC
'72 Dodge Demon again never weighed
440 with 8.5 compression & cast pistons
280/480 comp cam hyd
906 heads ported & gasket matched by myself
Torker intake
850 DP Holley
727 with rev manual valve body & hemi converter
8 3/4 with 3.23 gears
M50/14 Mickey Thompson soft compound street tyres
NOS plate 100hp jets
11.85 @ 116 mph not using NOS off the line
Mick
Post by Mick »
Pete wrote:Liking those tall tyres all those years ago, ehh? Mick ;)
I inboarded the springs and then cut the wheel arches out for more clearance, didn't look good but the body was rotting from the bottom up anyway.
Les, I thought a more modest set up might stir the imagination of those people just wanting a bit of street/strip fun.
Dodge Dart GTS 3150# with driver 440 RB, eagle rods, J E domes 12.7.1 comp, mopar.590 solid cam with 1.5 isky iron adjustable rockers, edelbrock RPM heads ported by MCH, milled to 76 cc , victor intake, QF 1050 dominator on a 2" adaptor, 727 reverse pattern, 9" UCC converter stalls at 5000 rpm.
31x10.5 hoosier slicks, dana 60 with 4.56 gears and a spool, 35 spline strange shafts, SS springs, front sections clamped adjustable rear shocks, calvert 90/10 on the front.
Best time and speed with with wheel spin 10.14 at 132.88 mph 1.47 60ft. On a good day averages 1.40-1.43
best ever 60ft 1.36
Les Szabo
Post by Les Szabo »
best ever 60ft 1.36
Yes Mick, its not just for 9>10 secs cars, its for all, all the way to your 16 sec car if you wanna post it up, my old 4 speed Cuda only ran 14.2, put your satelite up if you want, its all good info. The idea is for people to ask questions and discuss the set ups as well.
Am I the only one loving this thread ?
Ok. So a lot of members aren't into the race side of our cars , but I'd say it was about 50% ?
It's been a life long dream of mine to run a Mopar on the track. Its going to be a long and slow journey starting from the bottom rung of the ladder , but I'll chase it till I'm in my box !!!
God willing I'll be posting up a 318 b body more door on this thread later in the year. So let's have some stock times !
Great thread idea Les.
No questions yet. Still studying the posts. :read2:
Mick
Post by Mick »
72 Plymouth Satellite, stock full weight car, street tyres, 3.23 geared one legger, stock 904 auto, 318 ci dual plane offy intake, 600 edelbrock 4 barrel, headers
best 16.10 at 85.42 mph 2.52 60ft at York
66 Mustang, stock full weight car, street tyres 3.25 geared 9" one legger, stock C4 trans 302 ci, cast exh manifolds, larger than stock comp hyd cam kit, came with heavier springs and 1.6 roller rockers, edelbrock RPM dual plane intake and 600 edelbrock carb, which i swapped for a 600 v/s holley
best 14.87 at 91.96 mph 2.16 60ft at shakey
Cheers Mick :thumbright:
Les Szabo
Post by Les Szabo »
This was the 340 1971 Cuda as I bought it as posted earlier. I guess this is what you will find most of as far as Streetable tuning goes on a lot of cars.
All stock with stock interior, 3600lbs with Driver??...mods were>
Holley Strip Dominator
750 Holley
DC. .484/284 hyd cam, hyd rockers
Bone Stock 2.02 Heads
10.3:1CR w/steel shim h-gasket
Small Tube Headers
727 with Shift kit
B&M Super Holeshot 3500 verter
3.55 gears, 8.75" Posi
8 x 26" M&H crinkle slicks
Best was 13.2/101 mostly 13.3
that equates to around 300HP, put that in a 3300lb A bod and you will have 12.9 sec car.
Mick70RR
Post by Mick70RR »
1970 Road Runner
505 cu in
10.6:1 compression
MP 528 camshaft
CNC ported stealth heads
950 Proform carb
M1 intake
Headers
18 spline 4 speed
Gear Vendors overdrive
8 3/4 axle with Suregrip and 3.91 gears
Caltracs
275/60r15 street tyres
I run the car exactly as I drive it to work every day.
11.98 @ 117mph
Les Szabo
Post by Les Szabo »
And I reckon it would've run mid 11's with stickys :thumbright:
RW71
Post by RW71 »
Mick70RR wrote:1970 Road Runner
505 cu in
10.6:1 compression
MP 528 camshaft
950 Proform carb
M1 intake
Headers
18 spline 4 speed
Caltracs
11.98 @ 117mph
Wow, that is one impressive daily driver Mick! :notworthy: :thumbright:
John
Post by John »
OK,
As Les has just posted up a 383 build on another thread :-
69 Plymouth Satellite, full weight car, MT street tyres, 3.90 geared sure grip, built 727 trans with manual forward valve body, 3000 stall converter, 383 ci, ported 906 heads, solid cam, single plane intake, 750 double pumper, manual fuel pump, headers
best 12.40 at 110mph at the pod
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Les Szabo
Post by Les Szabo »
Yep, thats a lively 383, getting on for 400hp with a guesstimate on weight with driver of 3800lbs?.....
Les
John
Post by John »
Yeah was great to drive on the street too Les
I`m over 18 stone too :oops:
Now passed customs.
Now on route.
Now in posession.
JohnS wrote:Yeah was great to drive on the street too Les
That's the average weight for a 10 foot tall man !!! ;)
