Engine running - Power Valve query/nozzle query
GJUK
Post by GJUK »
Going to get ordered the following from Firecore:
Chrysler 361/383/400 "B" Low Deck Ready To Run FireCore Distributor
FireCore CD R2R Mini Coil FireCore CD R2R Mini Coil
383/400/426W/440 Pro-Fit HEI HT leads
Cheers John.
Depending on your header arrangement you may need some thermally protective boots to cover the plug caps - they often get burned to a cinder by headers; worth a check too.
GJUK
Post by GJUK »
Pete wrote:Depending on your header arrangement you may need some thermally protective boots to cover the plug caps - they often get burned to a cinder by headers; worth a check too.
Good point, I have some of these currently as my last set of ht leads were burnt to a crisp. Thanks for the advice!
