75 Dart swinger
Cam break in is the biggest issue so you can relax a bit.
It helps to pre-oil the motor if you can and check that oil is getting to the rocker arms. You have to take the dizzy out and have a long hex bar to achieve this as you drive the oil pump directly, I am sure it is the same on a small block as its bigger brethren.
Not the end of the world if you can't do this. Remember that a new tight engine will also generate quite a lot of heat compared to a run in motor.
