Yes timing is spot on now.
That's a good tip ta i'll check that before i do anything drastic.
Just tried that Pete- no fuel evident in the venturis so it doesn't look like a fuel leak.
I've fiddled some more , if i set the idle screws to 1/2 turn out i can open the primaries a 1/4-1/2 turn off closed but any more and the idle speed drops. Vac is around 5 or less here so even the 2.5 power valve i have in could be opening?
I just gonna give the carb one last internal check before i drill my first holes :shock:
Worst case scenario i'll have to weld up the holes/ buy new blades.
Watch this space...
YEAHHHH :woot:
Found evidence of a leak between chambers in the gasket behind the sec metering block. I hadn't renewed this one as the one in the kit was slightly different.
I made the extra couple of holes needed in the new gasket and on it went.
I set the butterflies to .045-ish up the transfer slots, mix screws to 2.5, whacked the carb back on and it fired up and idled straight off :D
I can now gently open the throttle and the revs slowly climb where before it just died!
AND this is BEFORE I went and drilled the butterflies ;)
Best tickover seems 1000-1200, vac 10.
Below that it gets very lumpy and vac drops to 5-6.
Thats good enough for now. Once it's home and the exhausts are done i'll do more fine-tuning and fit the right power valve, etc.
I've given it full throttle a couple of times and there's no sign of the secondaries opening- will they only open when it's under load?
Dart Vader
Post by Dart Vader »
Glad it sounds like you've solved that one Paul
Dont forget my offer..... :thumbright:
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Guy
Post by Guy »
db wrote:there's no sign of the secondaries opening- will they only open when it's under load?
Yep only under load, well at least thats when there meant to open. I found they would open when they felt like it, when driving my 340 Cuda. I saved fuel when I switched over to a DP when I was crusing but when I was out posing I used a fair bit more ;)
Well done!
(told you ;) )
Go and have some fun now :thumbright: :thumbright: :thumbright:
My exhausts are gonna have to exit ahead of the rear tyres so i'm looking at 28" max from collector flanges to silencer, max 18 x 5" diameter straight thru cans, then about 24" to the ends. (all in 2.5")
Are the silencers going to be far enough from the headers?
Can i get away with smaller silencers but still not give next doors dog a heart attack?
I can get the lot in stainless for around £180 and get my mate to weld it up for a crate of Stella
FIRST DRIVE ON PUBLIC ROADS :D :D :D :D :D :D :D
WHAT A BUZZ!!! Still ain't come down!
charger01
Post by charger01 »
Result . Now to cancel that wedding & get to the Euronats instead :D
Great youtube clip, credit to you for the work thats gone into the car.
Sounds great too!
db wrote:FIRST DRIVE ON PUBLIC ROADS :D :D :D :D :D :D :D
Congratulations, really pleased for you, especially after all the effort you have made to get to this stage.
Keep up the good work :thumbright:
Get a hair cut you hippy. :lol:
Dart Vader
Looking and sounding good Paul, next time I'm up your way you have to show me it for real.
Loving the stance of it too.
Oh, BTW, I AGREE, GET A HAIR CUT :D
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
TyreFryer
Post by TyreFryer »
Well done Paul! :thumbright:
Martin Walker
Thanks all, couldn't have done it without ya :occasion5:
And here's the scariest part of the trip home- my driveway :shock:
Eyes closed. Buttocks clenched.
