Jules' 1968 Charger R/T
PITA=Pain in the bottom.
Got a centre section, not perfect, but will do the job.
Really want to get rid as a whole grille, as the stripping down is a delicate process. So don't really want to spend the time doin it, as I've had my fair share of grille stip downs.
Your welcome to have a look & see what you think.
And a few more pics for y'all.....
Took the motor out today. Inspected the shells and crank. All ok.
Had a mass panic at first coz when we dropped the sump it looked like lots of bits of metal in the bottom, like a shell had gone.
It turned out to be the brittle rubber fragments of a valve stem seal.
Welds need to be ground down on the floor, but thats looking good now.
At least you can't see through it now
Been a busy puppy with the grille set up too. Stripped it from it's frame and have been cleaning the bits behind the headlight doors. Will stonechip all the bits first, but will give it a coat of black gloss to finish.
Stay Tuned......
Stay Tuned......
MMA/750
MMA/750
A few more to keep you amused
If anyone with a 68 charger could send me some pics of the rear light area and where the trunk closes in the corners above the lights that would be very much appreciated as you can see where we're working, and both sides are like it so we don't have a guide to go by if you see what I mean.
Nice close ups please would be great
Thankyou in anticipation for your help
Jules.
Jules.
MMA/750
MMA/750
- mopar_mark
