The AFR figures will give you a much clearer picture of what's happening and the solutions open to you with jets, pump shots and timing curves.
Interesting thread though, I love it when Dave and Adam talk technical...
This is EXACTLY why I started the threadCannonball wrote:surely thats the simple answer then pete, launch it with a lot off timing and have the timing retarded at a certain rpm in top for the long haul to the big end, you cant do a lot with the fuel issues so as a certain man would say use it as a bandaid,
i hate the electric side off things, but surely pete you could have a switch on the shifter that lets an msd retard know your in top gear and then that retards the timing x amount at a given rpm but only in top?????????????Pete wrote:This is EXACTLY why I started the threadCannonball wrote:surely thats the simple answer then pete, launch it with a lot off timing and have the timing retarded at a certain rpm in top for the long haul to the big end, you cant do a lot with the fuel issues so as a certain man would say use it as a bandaid,![]()
However, I have no automatic means of taking the timing out in top.....it may be a switch at the end of the day....
Even MSD say use a switch ManuallyPete wrote:[This is EXACTLY why I started the thread![]()
