Blue wrote:Did mine with -6 (3/8") Dave, not enough room for -8. You could use flexible line if there was enough room to get the hose ends in there, I used hard line so I could get the necessary tight bends. The other big problem is the size of the tube nuts, huge compared to the six pack ones, much fun getting a spanner onto those.
Thanks for that Blue. I will have to measure it but I think the standard fuel lines on a six pack are smaller than 3/8"? If so this would be an improvement.
Yeah I was thinking of keeping it simple by making a fuel log. I have -8AN from the mechanical pump to the filter and then to the regulator. I would like to run -8AN to a fuel log and then -6AN to each carb from there would be fine.
The other thing I would like to do is run -8AN from the tank to the fuel pump. The existing fuel sender and line is 3/8" to the pump but there are a few tight bends where the diameter is reduced a bit.
Any thoughts on how to plumb a stock tank with AN fittings without doing any welding and blowing our new tank and myself up? I take it those on the plastic tank work with nut/washers?
On a stock tank the lowest part of the tank is at the front but of course under power the fuel runs to the back so what to do????
