one rear brake getting too hot
that be the spirit
if they are not smoking the paint off the drums U R OK
Ive put a new flexihose on the rear and no better...still hot. Havent looked at the pushrod adjustment so will have a read up on that.
sorted for this year though...,MOTd, garaged up with just the occassional Winter run and hopefully the faries that break things while its parked up will fix this for me before the spring :D
Steve, if the pushrod was over adjusted it would stick all the brakes up. I did that. I know. The smoke is impressive :oops:
Gotcha Miles....Im stumped now then matey....hopefully they will bed in with use next year :D
they just adjusted up too tight
back em off till they stop rubbing
job done
check peddle doesn't go past 1/2 way and you are fine
Done all that Dave...nothing binding when up on the stands.....parking brake wound right off....rolls fine with brakes off on hills...creeps in drive easily etc etc....they just get really hot wthen I use her... :read2: w
Had a conversation with a friend yesterday about this issue and he imediately said, as Latil did, pushrod adjustment. Im definately going to check this. He reckons it might be causing residual pressure in the system as exactly the same thing happened to his car. Especially considering that both of my rears are gettin equally hot. Will have a look tomw. :thumbright:
By "pushrod adjustment" I take it you guys are talking about the master cylinder pushrod being too long and so not allowing the MS piston to move completely back?
Or have I got my wires crossed?
This is not adjustable as standard. It is determined by the pushrod length.
The set up is different between power and manual brakes. MP do an adjustable rod which you can then adjust the length of to get your brake pedal height off the floor perfect. Although I had to cut extra threads into mine.
Apologies if I have got my wires crossed and you are talking about something else.
Thats what Im on about Dave...my book gives a measurement with a very tight tolerance.
I am going to measure mine and compare it to the master cylinder. My mate ran through exactly what to do and says the one on his car is adjustable by a nut on the rod. I dont have this nut as far as I can recall. Was thinking of shimming the MC with washers on the mounting face just to test it to see if it cures the problem before taking more drastic steps :thumbright:
I may be wrong but as far as I know only the Mopar Performance aftermarket one is adjustable.
Power brake cars have a shorter rod that is on a bell crank lever. Manual brake cars have a longer one connected directly to the brake pedal.
Hang on that's rubbish. The power brake booster connects to the bell crank and there is a little push rod from the booster into the master cylinder.
It's been too long since i did this sort of thing... :roll:
I'll see if I can find a diagram.
This is the one in my book Dave. I just dont remember it having an adjuster on it when I fitted my new master cylinder....
Push rod.jpg (255.78 KiB) Viewed 405 times
Is screw 5-100-62 and adjustment on the power brake?? I don't remember seeing that before. :?
It looks like it Dave....that is the nut my mate was on about...
Looks like the same thing on my diagram Steve. I have no memory of seeing that adjustment before.
But then again what else is new. :roll: :lol:
