Couple of things.
Engine runs great now and I have no intention of changing pistons or decking the block.
A thinner gasket may (may) allow me to achieve suitable quench with the Ali closed chamber heads, but that will depend on how far the pistons are down the hole.
Mick the cam is quite modest
224/230@50, lift .47 and .48, lobe separation 110.
If I go ahead these heads need to be 'bolt on' and as Jon suggests I could have the heads milled to achieve desired clearance.
The new heads will up the compression especially if I use a thiner gasket, but being Ali the benefit of upping the static comp may be lost to the effective cooling of the heads. I don't want to loose performance here.
