MMA Forum Downtime
Re: MMA Forum Downtime
Well we're back up with the latest forum software version!
Hopefully you'll find it much better on mobile devices and the image resizing should be automatic now. Let me know if you find anything isn't working right or if there is any confusion with using the new version!
Also if there are any other features you think would be worth adding?
Cheers all!
Cheers all!
Martin Walker
- mustangbooks
Let's see if the image thing works....
Cool! Thanks Martin
Cool! Thanks Martin
“Yessss everising seems to be in order...”
- D7F2DCCB-1870-403A-A292-AB3AB34AD071.jpeg (68.61 KiB) Viewed 18987 times
Pimps in the Front
Hoes in the Back
Chumps in the Trunk
68 Dart Post
Hoes in the Back
Chumps in the Trunk
68 Dart Post
Looks soooooooooooo different, it can only be better thank you Martin
photo works too
photo works too
Wow, shiny new forum!!
It'll take me a few minutes to work out where things are but this is a brilliant look now.
Well done Martin!!
Well done Martin!!
Thanks Martin. I've had a quick look around and all looks good. On a bit of a road trip around the UK at the moment, will have a proper look when I get home
- IMG_5662.JPG (154.75 KiB) Viewed 18943 times
Clearly faulty.
It turns photos through 90 degrees.
Also the "Ugly Filter" is not functioning.
Great work, Martin; I know how much effort has gone into this conversion.
Where's the like button Pete. Why has it gone sideways, it was taken upright on my phone.
- mustangbooks
Martin, you've got all the BBCode, Smilies, IMG etc options switched off in here, was that deliberate?! I was going to try posting a 'portrait' oriented photo from my phone to see if it did the same as Derek's, but there's no longer an option to post images at all!!
You don't need the old img tags, you just click on the Attachments tab underneath the message area and click the Add files button to select an image to upload, smilies are to the right of the message box. Is this not working for you?
Martin Walker
- mustangbooks
There is no attachments tab in this subforum / thread! At least not one visible to me... I was obviously able to attach an image earlier on, before this thread was moved, which is why I suspect the options in this sub-forum don't allow some actions by ordinary users.
- Demon James
Loving this new Forum, Thanks Martin and co
I even managed video on the other thread
- MOPAR NATS 2017 (11).JPG (113.27 KiB) Viewed 18942 times
